tps adjustment.
i know there is a thing in vfaq but one of my buddys has a diagnostic tool and he can read the voltage to adjust it because its off. i dont know the voltage it is supposed to be at does anyone know. i need to know soon. thank you. there was nohting about voltage in vfaq.
I got this off alldata
Turn the ignition switch ON (but do not start the engine).
Check the throttle position sensor output voltage. Standard value: 400-1,000 mV
If there is a deviation from the standard value, check the throttle position sensor and the related harness.
Switch OFF the ignition switch.
VFAQ has this to say...
http://www.plymouthlaser.com/tps.htm
and check out post #8 on Tuners...
http://www.dsmtuners.com/forums/prob...#post151648149
**if you have a logger, be sure that your TPS reads 10% open in the "closed" position.
