Which Tranny?
Old Jul 3, 2007 | 09:38 PM
95420A's Avatar
Default Which Tranny?
Ok so I found a pretty decent deal on a complete 6 bolt setup with tranny and accessories but I was wondering if the 1g tranny will work in my 95 Talon TSI awd since its a 2g.
Old Jul 3, 2007 | 09:59 PM
2nd g eclipse gst's Avatar
Default RE: Which Tranny?
yeah it will
Old Jul 3, 2007 | 10:31 PM
racerx55's Avatar
wasnt there a gear ratio difference in the transfer cases and rear difffrom 1g to 2g?
you would probly be better off with a 2g trans.
Old Jul 4, 2007 | 08:34 AM
95420A's Avatar
See thats why I asked becuase I gotta make sure there are gonna be no problems with ratios or anything
Old Jul 4, 2007 | 02:22 PM
Sheijin's Avatar
hmm. I Have the same swap going on. I have a 1995 GSX Body and I bought a whole front clip 1g with the 6-bolt setup and a 1g transmission is already on it. I bought a 2nd gen transmission off of ebay but it's JDM and the guy said something about it being different in the speed sensor or something along those lines. He said that it was a cable system instead of an electronic and that all Japanese Domestics imported to the U.S. has this setup. Should I be worried about getting it or not? I'm having a nice performance shop do the swap because I dont have the time , So would it be able to be done there if there 'was' a setup-issue between the two models?
Old Jul 4, 2007 | 02:39 PM
Dusty Eclipse's Avatar
Are they both AWD, before we even start this?
Old Jul 4, 2007 | 03:11 PM
Sheijin's Avatar
yea the engine I have is the 1g 4g63T with an AWD Transmission already bolted up to it. And I ordered a 2nd Generation AWD Transmission for it
Old Jul 4, 2007 | 04:34 PM
95420A's Avatar
So my question is do I need to get a 2g tranny
Old Jul 4, 2007 | 05:35 PM
racerx55's Avatar
from my understanding the 2g trans is stronger, and it actually has mounts on it so you dont break the ears off the block like 1g's constantly do.
read up here for gear ratios on different cars
http://www.vfaq.com/mods/Trannies.html
by reading that either one will work.
but if i had the option i would use a 2g trans IMO
Old Jul 5, 2007 | 02:59 AM
Sheijin's Avatar
Any idea about the cable/electronic speed sensor ?
