Transmission Problem
My 5 speed tranny in a '97 Eclipse with 2.0 L is most of the time hard to shift into first gear. You have to let thet clutch out in neutral and then try to get it into 1st gear. Same thing for reverse. It goes into 2nd most of the time with occassional difficulty. Sometimes when you first start up the car, the shifter is stuck in neutral nd you have to work with it ti get it to move into any gear. What is the probable problem(s)? It is taking the fun out of driving the car. Should I take it to a transmission shop for a diagnosis? Could it be a clutch related problem?
Thanks
Thanks
