transmission problem
Old Oct 28, 2004 | 10:54 PM
fordmanturnedmitz's Avatar
Default transmission problem
i have a 94 eclipse with a 2.0L DOHC, TURBO, and AWD. The car shifts fine however at slower speeds down to an idle i hear a grinding noise. I don't think it is the output shaft seal but it could be the transfer case. Anyone come across this and does anyone have a used transmission that i might even purchase????
Old Oct 29, 2004 | 12:49 AM
jdmeclipse92's Avatar
Default RE: transmission problem
your gears might be stripping. crud on the flywheel. but if you need a transmission try finding one from a 91-93 galant vr-4. the gear ratio is better and will bolt right up. they are hard to come by but well worth it.
mike in nc
Jun 12, 2006 02:37 PM
03Sport
May 3, 2006 02:20 PM
mysterio2099
Mar 10, 2006 01:53 PM
andrewfrank9
Mar 2, 2006 10:22 AM
office888
Nov 20, 2005 06:31 PM
