2000 sport transmission problem
Old May 24, 2006 | 02:30 PM
mike in nc's Avatar
Default 2000 sport transmission problem
I have a 2000 montero sport, 4x4,aprox 125,000 miles. I will be driving along, and the trans will downshift on its own, does not matter how fast I am going. The neutral indicator and the drive indicator will flash alternately. the service engine light will come on. I can pull over and shut off the engine and start back up. It may be ok for a while after that, but will happen again sometime. also, once this happens the first time the service engine light will be on all the time. I have had it at the dealer for 6 weeks, they tried several things, but cannot find the problem. Finally gave up on them. I would really appreciate help
Old May 29, 2006 | 02:32 AM
mxmikie's Avatar
Default RE: 2000 sport transmission problem
check your battery and battery cables if the alt is going it will do the same thing
Old May 30, 2006 | 03:02 PM
off roader's Avatar
Also, may or may not be directly related but when was the last time you changed your tranny fluid? It should be done regularly but most owners don't do it as instructed in the owners manual.
Old Jun 2, 2006 | 01:32 AM
mike in nc's Avatar
I have had the transmission fllushed and the fluid changed about a month or two before this started happening, I though about haveing it done again just to make sure the correct fluid was put in
I have never thought about the alt causing this, how do I find out if it is going bad?
And thanks for your replies
Old Jun 4, 2006 | 02:46 PM
mxmikie's Avatar
have the battery and alt load tested a bab battery cable will do the same thing
Old Jun 6, 2006 | 04:34 PM
mike in nc's Avatar
I mentioned that to the mechanic that has it now. He did say that he had a code for the speed sensor. He was going to change it and see what that did. He also mentioned he was getting a 3 digit code, 770. He said he did not know there were any 3 digit codes, and that he did not know what it was for
Old Jun 6, 2006 | 06:20 PM
off roader's Avatar
ORIGINAL: mike in nc
Mike,
That flush would be the first thing I'd check. Wrong fluid means tranny rebuild time which is $$$$$$$$$$$.
I do the flush annually and make absolutely sure they put the correct stuff in my '90 AT.
HTH
Old Jun 6, 2006 | 08:06 PM
Winshawn's Avatar
Take it back to the dealer and have them flush your tranny with Genuine Mitsubishi Diamond SP III fluid.
Old Jun 12, 2006 | 02:37 PM
mike in nc's Avatar
well, the speed sensor was changed, and I have been driving it around a little to test it out, of course the last time it took about a month before it acted up again. I need to take it on a trip to check it out. I will keep you all informed. In the mean time, thanks to all of you for your input
jimithing27
Apr 16, 2021 12:17 AM
levanixai
Feb 24, 2014 05:54 PM
disturbed1
Mar 15, 2013 09:33 AM
disturbed1
Mar 14, 2013 11:31 PM
JFENDERSON91
Oct 10, 2012 11:24 AM
