Trying To Narrow It Down...
Okay, so the question has been asked numerous times, but I need to ask it again.
Myself and a friend were tuning up my car about a week ago, and we were doing spark plugs. He tightened the plug in the first cylinder so tight that I stripped it today when I attempted to take it out to check it for oil. I think my gasket has a leak. Well, it's stripped, so I go down to autozone to get a bolt extractor. After finally breaking the top off of the spark plug, and getting all of the ceramic out of the well with an air compressor, I extracted what was left of the bolt. I replaced the spark plug, and now my car is bogging. It's not happening at a certain speed though, when I hit a certain RMP, it starts sputtering. I thought it may have been from my vented BOV, but even after reconnecting it, it still sputters...But the problem didn't start until after replacing the spark plug...What could the problem be? Thanks.
-brandoN^-
-brandoN^-
Well, the center piece was pulled out while trying to remove the plug. Before the plug was extracted, I took a air compression hose, and blew it all out...Looking in the well, there was no more in sight. After that, I took the bolt extractor, and unscrewed it. It was in pretty tight, but it came loose.
If something did happen to fall in, or I did strip the threads...Where would I go from there? Thanks.
-brandoN^-
-brandoN^-
If you DID strip the threads you'll need to get them tapped you also may need to get them fixed completely I don't know what exactly the full repair process entails but tapping it is probably going to be done with the head off the car. Just for the sake of keeping metal shavings out of the cylinder. If you can get a hold of a extendable mirror small enough I'd look around in the cylinder see if there's anything floating in there just to be safe.
well the options that can fix this are risky for ex my 95gs somone stried one the sparkplugs out "previous owner" and put in a helicoil which makes it so bolts can be put back in well he put it in a little to far and the piston came up hit it mushroomed it and bent every valve. bet thing to do see if you can fine a newhead in a junkyard and get it rebuilt ot put the parts from your head in it. Oh and if you do not let the block cool down you will strip out the plug holes in the head.
ORIGINAL: Sanguinius
Hey everyone. Thanks for all of the help so far. I woke up late this morning, so I didn't have time to play with it. I ended up carpooling to work so I didn't have to drive my car. Last night, I pulled all of the plugs, and when I pulled the plug from cylinder 2, a LARGE chunk of the white ceramic was craked, and fell off, exposing the inner conductor. I am assuming this fouled spark plug is causing the bogging...At least, I hope it is! If not, I'm going to end up buying a new engine. I know I can just replace the head, but I'd rather get a brand new one. Maybe an import from Japan. I know a shop where I can get one between 1100-1500...Well, at least, that's what my uncle is telling me. I still need to go to this place, and check it out. I'll post an update when I get home today. I'm going to stop at an auto store on the way home to pickup, yet, another spark plug. Back to work. Thanks again!
-brandoN^-
-brandoN^-
ORIGINAL: brandoN^gsT
-brandoN^-
-brandoN^-
