tune a 420a ?
Old Nov 20, 2006 | 01:13 AM
99madewell's Avatar
Default tune a 420a ?
what is a good tool to use to tune a 420a ? ive searched through some stuff but have not found what im lookin for exactly. ive got basic mods. header, cat back exhaust, CAI , k&n , hotter coil and plugs , yada yada.
is it even worth the effort or money?
Old Nov 20, 2006 | 09:45 AM
Default RE: tune a 420a ?
without any type of fuel system and a turbo its useless.
Old Nov 20, 2006 | 10:21 AM
RCJr9186's Avatar
you aren't going to get much out of a tune but you can get an SAFCII. or you can get a Venom 400 chip. basically once you get to 25% throttle it goes from stock tune to the most agressive tune you can get out of it. i have it and there's definately a difference. i'm actually selling mine if you are intersted in it.
Old Nov 20, 2006 | 01:34 PM
99madewell's Avatar
hmmm......just as i suspected. why are you selling the venom? it pretty much just tricks the computer right? how much ?
Old Nov 20, 2006 | 01:39 PM
RCJr9186's Avatar
it doesn't "trick" the computer, it simply changes the timing, it tells the computer don't use this timing... use THIS timing. i'm selling it because i'm about to turbo my car and if i run my turbo with that timing on my car i'll end up with a very bad ride. it goes in stores for about 300 i'll sell mine for 200
Old Dec 3, 2006 | 05:40 PM
djfrog2001's Avatar
How noticable is the difference with the chip?
Old Dec 3, 2006 | 07:00 PM
djfrog2001's Avatar
Since the general consensus is that the 420a is slow-*** engine that needs turbo to be worth a damn, what is a good turbo kit that can be put in and at what approximate cost?
Old Dec 3, 2006 | 07:02 PM
There are many turbo kits out there and htey are usually like 3k+
Old Dec 4, 2006 | 10:17 AM
do a search please, that has been anwered alot on the forums
Old Nov 8, 2007 | 10:20 PM
DunDun96's Avatar
ORIGINAL: RCJr9186
I also have an RS that im working on and I was going to get the Venom 400 then I changed my mind and started looking at SAFC II 's but then somebody told me that those air fuel controllers are pointless unless you have a turbo.....
Is this true, is it goin to be a waste of 300 bucks if I buy one?
