Turbo issues
Old Jun 5, 2009 | 12:11 PM
Hitmachine101's Avatar
Talking Turbo issues
hey guys -- new to the entire world of force induction -- just picked up a 95 GSX with 44K on it and the turbo whines for about 3 or 4 shifts till shes warm and then goes away -- did an oil change to what specs recomend ( 5W 30 ) and it still does it -- do i need to rebuild the turbo? what could happen to it if i leave it alone? is there anything i can do to make it stop?
thanks guys -- appreciate the help
Old Jun 5, 2009 | 05:04 PM
dsm1990gsx's Avatar
Pull the intake hose off and check the turbo for shaft play. Also check the compressor wheel its probabaly making contact with the housing.
Old Jun 5, 2009 | 06:50 PM
like he said. pull the intake off and first see if the shaft on the turbo fins can move side to side....then see if it can move in and out
Old Jun 9, 2009 | 11:20 PM
ok ill do that tomorrow when i get a shot -- if it does have play in it side to side or i can move it in and out then im guessing that means its going eventually....
either way its like 80 bucks for a rebuilt stock turbo on ebay so im not particually worried, just trying to learn a thing or two
Old Jun 10, 2009 | 06:34 AM
You would be more worried about the turbo if the shaft play is IN/OUT rather than side to side. But yes if it has a decent ammount then it needs to be replaced. And i wouldnt buy one from ebay.
I would try these guys
http://www.precisionturbo.net/
or look around for someone that can do a rebuild for you.
Old Jun 10, 2009 | 11:20 PM
ok took off the intake today and got my hands on the turbines -- seems tight side to side and in and out -- no play whatsoever
i did forget to mention that the down pipe has a leak in it -- you can hear it pretty well so we are replacing it here shortly
would the lack of back pressure possibly be causing the whining on the turbo while it warms up?
and thanks for the website - lot of info there
Old Jun 11, 2009 | 06:24 AM
are you sure the whine is the turbo and not the tranny?
Old Jun 11, 2009 | 09:36 AM
pretty sure its not the tranny, but ill go check the fluid, ill change it if it needs it, see if the whine goes away.
Old Jun 11, 2009 | 01:25 PM
dsm1990gsx's Avatar
Check the transfercase and rear diff fluid as well.
Old Jun 15, 2009 | 11:48 PM
Question
checked all of those -- tranny rear diff transfer case -- all good, the whine is deff comming from the turbo -- but nothing is giving me reason as to why its doing it....
guess im stumped on this one, any other ideas guys??
