Update on my 99 GST...
Old Feb 13, 2007 | 07:35 PM
kaiba408's Avatar
Default Update on my 99 GST...
First off the squeak in my clutch pedal bushing is finally gone, alittle dielectric grease finally worked wonders. And 2nd, I finally got my front pipe installed BUT something came to my attention in the process. Keep in mind I had the OEM Cat installed first with new gaskets as well for Smog Referee purposes. I left the rest of the aftermarket exhaust system alone.
So today when the front pipe came off there was build up on the Cat/front pipe gasket from a leak. I figured it was because it was an OEM cat and an aftermarket front pipe. I knew I had an exhaust leak already coming from the front pipe area, 1. because I could hear it 2. I had a lean mixture during a smog test (but still passed). I asked the techs to make sure the leak was gone when they were done and they said yeah its gone. When I got home after all the work was done I listened for the leak again and I dont know if its me or not but I can still hear a faint hissing sound from under the car, not a steady hiss but off and on. Please tell me the slight hissing sound is not a leak!
I intend to go back to have them check it out again in a day or two to make sure the leak is actually gone. The exhaust manifold, front pipe, and cat converter are all now OEM with new gaskets. I hope its fixed.
Old Feb 14, 2007 | 06:52 PM
kaiba408's Avatar
Default RE: Update on my 99 GST...
No exhaust leak to be found WooHoo! And I noticed there was a small decrease in RPM surge when I hit the gas. Before, pretty much anything more than 50% throttle started a RPM surge...now its good to accelerate at 50%. I havent pushed it passed that and I dont intend to just in case the clutch still burns up. Next on my list is either the intake revert to stock or new Act clutch.
Old Feb 16, 2007 | 04:29 PM
fcukwithmeprelude's Avatar
Good ol' eclipses man.
Word of advice: don't buy advance auto's cheapest clutch. After breaking in correctly, it started slipping in about 15,000 miles.
Old Feb 16, 2007 | 04:34 PM
just go with an ACT 2100 or a 2600 depends on the future mods you plan on getting
Old Feb 16, 2007 | 05:51 PM
kaiba408's Avatar
Thanks, yeah i was going to go with the Act 2100 street clutch. I just hope my flywheel can be resurfaced...those things are expensive just for the one part.
Old Feb 16, 2007 | 05:57 PM
theres a pretty good chance you can just resurface it since you havnt really pushed the car
jpmontero98
Jan 22, 2008 05:09 PM
Gstfat
Oct 26, 2007 06:14 PM
baker_sk8er37
Oct 14, 2006 10:38 PM
JMC
Apr 18, 2005 02:17 PM
98GstSpyder
Jun 10, 2004 11:11 AM
