upgrade to a 16g......
Old Sep 8, 2007 | 03:00 PM
BrunoBoy650's Avatar
Default upgrade to a 16g......
sup guys, well now im thinking of gettin a evo3 16g. well i have the 14b on it right now. my Q is, if i get the 16g, what else do i need? do i need a new install kit? or can i use the one i have? or can i just buy the turbo?
Old Sep 8, 2007 | 03:06 PM
tjbiker031's Avatar
Default RE: upgrade to a 16g......
you need the install kit, new clutch, maybe flywheel, fuel pump, injectors, DSM Link, Wideband, and the list goes on.....somebody had a list up here a while back for all that.
Old Sep 8, 2007 | 03:18 PM
jlh077464's Avatar
you dont "have" to have all that. You just want see much power diffrence until you do upgrade all that.
Old Sep 8, 2007 | 04:12 PM
ORIGINAL: tjbiker031
why would i need all that? i have a 2500lb clutch, im getting a 190 pump, i ordered my logger, and i have a SAFC..........
Old Sep 8, 2007 | 11:24 PM
2nd g eclipse gst's Avatar
hey brunoboy emonz is selling his 16g off his evo for like 400 bills obo, pm him
Old Sep 9, 2007 | 02:42 AM
That wont bolt up to the stock manifold though.
Just stay away from ebay and those 'GT' series 16gs and you will be okay. If you want to crank up the boost... well i dont even need to tell you what you would need, you should already know
Old Sep 9, 2007 | 02:58 AM
nah but i think emonz is selln the mani with it
Old Sep 9, 2007 | 03:09 AM
I still dont think it will bolt up... exhaust would be different
Old Sep 9, 2007 | 04:58 AM
racerx55's Avatar
why wouldnt it bolt up? theyboth use a TD05 exhaust housing
upgrading from a 14b to a 16g you dont NEED anything unless your gonna crank the boost even higher.
its all direct fit, evrythings the same. ive swapped plenty of turbos and reused gaskets and the brass seals on the oil and water lines without ever having leaks.
Old Sep 9, 2007 | 08:30 AM
you would need a custom manifold I think to fit the Evo turbo because the turbo on the Evo is 180degrees opposed frm a DSM. So when turned it would prob cause the o2 housing to sit to far out. On top of that a custom downpipe maybe needed as well. BUT at least it is an awsome 16G would be a cool upgrade it you fit it
