upgrade 420a
Old Aug 19, 2007 | 09:07 PM
davidmitsusrock's Avatar
Default RE: upgrade 420a
then what the **** is wrong with it? i know plenty of people with stock 420as that get at least 25. and of course its slow but so what.
Old Aug 19, 2007 | 09:53 PM
chopper1's Avatar
I'm trying to figure it out. Went and got the codes Friday. It had9 of them, PO106, 300, 301, 302, 303, 304, 403, & 1390, and another EGR related one. Imagine that, it's not there.
The air fuel ratio meter stays at max lean. I'm assuming it was hooked up correctly which means the computer is seeing the same and adding fuel. Bought a new O2 sensor, but figured I'd check the plugs and do a compression check first, just to see what is going on.
Old Aug 20, 2007 | 12:33 PM
RCJr9186's Avatar
honestly if you are looking for a quick car than you need a new one. i'm not just being biass b/c i used to have one i'm just telling you that to make urcar even reasonably quick you will need to dump about 4-5k into it. but when you think about it, you can buy a GS-T for 5k so its really not worth it.
Old Aug 20, 2007 | 12:39 PM
95EclipseGS95's Avatar
ok thanks
Old Aug 20, 2007 | 03:39 PM
antlip's Avatar
We should get a sticky on this forum like we do in the outlander forum. Post a sticky ontop of how to make the 420a motor fast orrrrr DONT TURBO YOUR 420a. Cut down on the 5 post a day of how do I make my gs fast or can I turbo my gs questions.
abnsapper2
Aug 31, 2008 08:17 PM
halfasss101
Sep 4, 2007 02:35 PM
Miic
Jan 11, 2004 11:42 PM
Topspin800
Nov 16, 2003 12:32 AM
Mrfirefox
Jul 10, 2003 06:14 PM
