vacume hose?
Old Oct 14, 2005 | 01:02 PM
DixonsGst's Avatar
Default vacume hose?
alright i have a question...I have a 97 gst and for those of you that have one...you know the hose the runs from the valve cover to the intake? Well i keep on getting oil sucked down into the intake from that hose. Is it possible to cap the intake hole off and put a breather filter on the valve cover hole to eliminate this oil problem? Will it create any problems?
Old Oct 14, 2005 | 03:07 PM
DSMTalonAWD51's Avatar
Default RE: vacume hose?
yes. but put it back when you get your car smogged or you will fail
Old Oct 14, 2005 | 04:06 PM
Sanguinius's Avatar
You're talking about the PCV hose right?? When was the last time you changed your PCV valve? It should be done every 20-30K miles OR once a year. if that valve is bad you could blow the vlave cover gasket or it may be the culprit for your current dilema. The part will cost less than $10 (Installed even at most shops LOL). It might be worth checking out.
Old Oct 16, 2005 | 02:17 PM
DixonsGst's Avatar
no not the pvc hose...the hose that runs from the valve cover to the intake tube. Plus, in my state they dont check for emissions. but other than that will it create any more problems?
Old Oct 17, 2005 | 12:12 AM
no problems its fine. just pull the hose out, or install a breather filter/catch can in between that hose to catch the oil
Old Oct 17, 2005 | 12:18 AM
Sanguinius's Avatar
Yep that's about the extent of it. Sorry I was thinking of the wrong hose LOL.
Old Oct 17, 2005 | 10:17 AM
slow420a's Avatar
If you do a catch can make sure that you do put a breather on one of the holes of the catch can. I hooked a greddy up to mine when I first got the car per the instructions and for a while I couldent under stand why the car was leaking so much oil.
Old Oct 17, 2005 | 02:52 PM
Sanguinius's Avatar
You'd think they'd put something like that in the instructions?....
Old Oct 17, 2005 | 06:13 PM
slow420a's Avatar
ORIGINAL: Sanguinius
na it was all in jap.... I just followed the pics.
Old Oct 17, 2005 | 06:25 PM
Sanguinius's Avatar
Well then you either need to learn to read Japanese or find english instructions next time eh? lol
