Visual Turbo Breakdown
Old Sep 11, 2006 | 02:16 PM
2insane's Avatar
Default Visual Turbo Breakdown
Hey Everyone!
I read the sticky on turbos, which is great btw! I also searched, maybe the wrong words, but I can't find what I am looking for! I have tried How Stuff Works vfaq.com and nothing! I need a website to breakdown visually a turbo and explain everything about a turbo! I want to upgrade like I stated in previous posts but I don't understand some of the options some sites ask. For instance the difference between .48 a/r and .82 a/r. what is a/r?? wheel sizes etc etc. If I have some visuals and explanations to go with it, it would help me out. Please help me out!! Emoz Sanguis(sp) and Slow420 please chime in
Thank You
Old Sep 11, 2006 | 02:36 PM
Default RE: Visual Turbo Breakdown
a/r is the ratio of the area of the compressor housing to the distance from the center of the tube to the turbine shaft. It basically tells you how restrictive a turbo will be and how fast the spool up will be. Smaller a/r means faster spool up but more restrictive so less power it can generate, and larger a/r is just the opposite.
Hope this helps
Old Sep 11, 2006 | 02:40 PM
ok garrett also has a great write-up on this stuff that has basic and then much more detailed stuff also. Try here and see if you need more than 101 then check out 102
http://www.turbobygarrett.com/turbob...o_tech101.html
Old Sep 12, 2006 | 02:47 AM
2insane's Avatar
You ROCK!! Thank You!!![sm=exactly.gif]
Old Sep 12, 2006 | 11:38 AM
N/Teclipse's Avatar
Awesome info, got a little lost when it got to 103 lol.
Old Sep 12, 2006 | 12:05 PM
RCJr9186's Avatar
you said you got nothing off of HowStuffWorks??? http://auto.howstuffworks.com/turbo.htm
Old Sep 12, 2006 | 12:28 PM
ORIGINAL: RCJr9186
thats what i was thinking too cuz i know that site had a good write-up too, but i must say that garrett does a great job
Old Sep 12, 2006 | 12:44 PM
RCJr9186's Avatar
never seen Garret's but i have learned a TON of stuff about cars on that website, if any newbies ever feel the need to read lol look their article on Cams, it's pretty cool, it also gives 3-d views of how they work and how V-Tec's work.
Old Sep 12, 2006 | 01:56 PM
2insane's Avatar
HSW doesn't get in depth that I wanted to know.. the site engineer showed is what i needed. I wonder if we can get that site as a sticky in the write up of turbos.
Old Sep 12, 2006 | 02:26 PM
well ive been trying to get a FAQ/How to section here. I guess this will be one of the first topics for it.
