Waterpump cause blog?
Old Mar 13, 2007 | 11:41 AM
  #21
maxboost22's Avatar
Default RE: Waterpump cause blog?
I meant when im driving the car. It wont go pass 3k rpm. It sounds like a loud Thump and feels like you're not getting power.
Old Mar 13, 2007 | 12:28 PM
  #22
could possibly be fuel cut. Im not 100% on that though because a misfire can often be confused for fuel cut. But if it is fuel cut then it may be either an air leak, clogged fuel injectors/lines, bad fuel filter, bad fuel pump. Since you already said there is no boost leak (and im assuming you did a test to check that) then its not the air leak. So i guess start with some fuel system cleaning. This is if its fuel cut. If its just misfiring then maybe its something in the ignition system.
Paulo japs
May 19, 2015 11:30 AM
illycut
Sep 4, 2008 05:47 PM
micahman
Aug 3, 2006 02:46 PM
Trader4Less
Feb 17, 2005 06:04 PM
