wats stock power for gst
Search stock 1/4 car times and there are a bunch of links
here is one of them
http://www.albeedigital.com/supercou...0-60times.html
here is one of them
actually i should specify its not the BCS your remove. Its the BCS restrictor. Its a small peice on the BCS. Here is another good source for the power and specs
http://consumerguideauto.howstuffwor...-eclipse-4.htm
So from these two sources here is what you were asking
HP: 210hp to the crank
Torque: 214 ft-lbs
Boost: 10psi
1/4 mile: 15.5 (i think its alittle better than this however)
0-60: 7.4 sec
Torque: 214 ft-lbs
Boost: 10psi
0-60: 7.4 sec
