wats stock power for gst
Old Mar 18, 2008 | 09:44 PM
KY95gst's Avatar
Default wats stock power for gst
ive heard so many differnt things. wats the stock horse power, torque, boost, quarter mile seconds, 0-60
or give me a link to this or something
Old Mar 18, 2008 | 09:47 PM
darknigh7th's Avatar
Default RE: wats stock power for gst
210hp, everything else not so sure. but just to forwarn you, please use the search button.
Old Mar 18, 2008 | 11:25 PM
tjbiker031's Avatar
i thought it was 210 at the crank?
Old Mar 18, 2008 | 11:53 PM
Stock 1/4 I believe is mid to low 15s, power is 210, and torque is 214. Stock boost is 12psi, 0-60 is mid 6s
Old Mar 19, 2008 | 02:53 AM
it is to the crank thats why i posted that..
Old Mar 19, 2008 | 06:15 AM
actually sebba 10psi i beleive is stock boost for a gst however with a simple removal of the BCS you gain 2psi. So thats why most of the time your gonna see 12psi
Old Mar 19, 2008 | 06:48 AM
dsm1990gsx's Avatar
Search stock 1/4 car times and there are a bunch of links
here is one of them
http://www.albeedigital.com/supercou...0-60times.html
Old Mar 19, 2008 | 06:57 AM
actually i should specify its not the BCS your remove. Its the BCS restrictor. Its a small peice on the BCS. Here is another good source for the power and specs
http://consumerguideauto.howstuffwor...-eclipse-4.htm
So from these two sources here is what you were asking
HP: 210hp to the crank
Torque: 214 ft-lbs
Boost: 10psi
1/4 mile: 15.5 (i think its alittle better than this however)
0-60: 7.4 sec
Old Mar 19, 2008 | 01:34 PM
yeah it is 10psi, we removed the bcs restrictor from bestwiseguys and his jumped up and i believe mine was already removed.
Old Mar 19, 2008 | 02:46 PM
bestwiseguy's Avatar
actually you got that backwards jon lol. Yours was still in place and mine was already gone, which explains why ive always boosted around 14 lbs.
