weird grinding noise
Old Mar 29, 2007 | 05:37 AM
BrunoBoy650's Avatar
Default weird grinding noise
like i know when i start up cold, it squeals like my belts. but then sometimes i hear like a griding from the pulley's. then itll go away. when i turn sometimes i hear a grinding noise too which seems to be the same noise and it goes away after a little bit. and i was on the freeway and i heard it for a little while too. what is it? and how much estimate to fix it?
Old Mar 29, 2007 | 09:25 AM
Default RE: weird grinding noise
sounds like something with your power steering pump
Old Mar 29, 2007 | 10:08 AM
RCJr9186's Avatar
i 2nd that! when i'm sitting still and i turn my wheel i can hear the pump but it's nothing like grinding. more like a humming noise untill i stop.
Old Mar 29, 2007 | 02:46 PM
can it be the power steering when i sit at idle? and not turn the wheel also? because i hear hit at warm up sometimes too
Old Mar 30, 2007 | 02:04 AM
matt02708's Avatar
check the tensioner it could be rusted out.
Old Mar 31, 2007 | 01:15 AM
I Drive Naked's Avatar
If you're hearing that noise on turns, you should check your steering rack.
Sterring noises can occur at idel, but turning would be more noticeable.
And remember what I said about my belt noise, it was the pulley and the serp. belt.
Old Mar 31, 2007 | 02:26 PM
TheAdvocate's Avatar
It will actually make a lot of noise when your just idleing.. I would check the fluid first. I had a leak in my line and I still havnt gotten the grinding noise to go away 100%... But I would say your prolly a little low on fluid if its makin that noise..
Old Apr 1, 2007 | 06:01 PM
ok well heres the verdict, i think the pulleys need lube lol, the belt thats squeeling is when i turn on the heater, and the heater doesnt seem that hot anymore, whenever i turn my wheel theres a small chirp, my rotors are gone sounds like grinding on the left driver side, so i just bought new front rotors and pads............and i got pulled over for street racing last night, great.
Old Apr 1, 2007 | 11:45 PM
antlip's Avatar
So is it the belts? Rotors? Heater?
Sucks that you got pulled for street racing isnt that 4 points?
Old Apr 2, 2007 | 02:04 AM
ORIGINAL: antlip
rotor making the grinding noise that i thought was the pulley, uhm the pulley is still making a slight noise, the heater isnt as hot as it used to be, and when i turn on the heater, it makes a chirp noise from a belt and its the same noise i get from turning my wheel right and left.........idk what else to say. someone wanna identify it for me?
rallyendeavor
Jul 20, 2006 11:22 PM
iceman
Feb 4, 2006 12:00 AM
KillerEclipse
Jan 22, 2006 10:18 AM
Timmay
Oct 12, 2005 10:50 PM
mapa244
Jul 30, 2005 07:05 PM
