Weird Light?
Old Jul 17, 2008 | 02:16 PM
Scubba.steve's Avatar
Default Weird Light?
Hey all, this light just poped on in my talon. Can anyone tell me what it is? Thanks
Old Jul 17, 2008 | 03:43 PM
darknigh7th's Avatar
Default RE: Weird Light?
..... i have no clue what the hell that light is lol.
Old Jul 17, 2008 | 04:10 PM
dsm1990gsx's Avatar
Low coolant indicator?
Old Jul 17, 2008 | 06:26 PM
CJeclipse09's Avatar
check your fluids.
Old Jul 17, 2008 | 06:50 PM
Some kind of fluid... might even be windsheild washer fluid.
Old Jul 17, 2008 | 09:28 PM
silvercoupe97's Avatar
Check your rear washer fluid resevoir. I want to say that the 420a models have one in the front and one in the rear (rear wiper equiped).
But yes, check all your fluids.
Old Jul 18, 2008 | 01:51 AM
Well about a month ago i had replaced my fuel filter, Filter sets right under the washer bottle. When i was taking the bottle out i had broke the plastic on the pump that feeds water into the tubs then to the nozzles. o now if you put water into it, it just flows right out the bottem. Also i noticed today while i was under the hood, On my overflow bottle there is a pigtail that determines how much antifreeze/water you have in your system. The pigtail had broken and is just sitting their. I belive this light to be the water sensor in the overflow bottle but not sure.
Old Jul 19, 2008 | 02:29 AM
Perhaps you should replace that plug or reconnect the wires so that you can rule it out.
Old Jul 19, 2008 | 02:32 AM
****ING BOARD!!!
Old Jul 19, 2008 | 02:33 AM
The windshield washer fluid resevoir doesn't or shouldn't have one for the front and if it does, the sensor is external from the windshield washer pump. Have you checked your spare tire well for the rear washer fluid yet?
