weird noise got a vid please help my gs-t
Old Mar 16, 2008 | 07:15 PM
Default RE: weird noise got a vid please help my gs-t
That is either a pulley that is loose... or a spun bearing.
Possibly something in your valve train
Old Mar 16, 2008 | 09:02 PM
Dusty Eclipse's Avatar
Nate spun the bearings in his 2G, maybe hed know more...
Old Mar 17, 2008 | 03:01 AM
50ul }{4ck3r's Avatar
ORIGINAL: Dusty Eclipse
well lol...that about the same sound my gst was making right before it crankwalk!!!!
i would say a spun bearing!!!
Early signs of The Messed up CrankWalk!!!!
Old Mar 17, 2008 | 07:07 AM
anko_kun's Avatar
ORIGINAL: 50ul }{4ck3r
well thats just grate news lol well a built 7bolt here i come
Old Mar 17, 2008 | 11:05 AM
ORIGINAL: anko_kun
lol a new 7 bolt.....get a 6 bolt it will never do it again
and listen to the right side bottom of the motor and have someone listen while the gas is applied!!
thats were that sound should be coming from....
Old Mar 17, 2008 | 11:50 AM
RCJr9186's Avatar
i hear a lot of odd sounds lol. lifter tick, sounds like a possible boost leak and the unknown ticking sound... that you should probably take the turbo off and examine it first before jumping to any conclusions.
Old Mar 17, 2008 | 01:02 PM
I listened to the video again.. and now all I hear is lifter tick above an exhaust leak. I think you are okay.
Old Mar 17, 2008 | 01:16 PM
RCJr9186's Avatar
that's what i thought as well but it's hard to depict each sound. it's still not a bad idea to take a stock turbo off for an inspection, you should do that anyways once in a while to check for shaft play, oil, etc etc.
Old Mar 18, 2008 | 06:16 PM
anko_kun's Avatar
well i found out what it was i have 4 lifters going out i work at a nissan dealership that was a mitsu one before and my trainer was a mitsu master tech so he knew what is was right off the bat so soon new lifters will come and all will be good _ no spun bareings nada with the turbo so all will be good
Old Mar 18, 2008 | 06:45 PM
Yeah I understand that much.. but there is an exhaust leak over top of the lifter tick sound.
