were is the fill point on my transmission
Old 09-08-2007, 04:10 PM
kenlrw39's Avatar
Default RE: were is the fill point on my transmission
i got it. can you tell me whats the difference between the mitsu fluid and regular fluid?
Old 09-08-2007, 10:32 PM
estraw's Avatar
if its in neutral when it makes the noise, its most likely your bearings. if you push the clutch in and the noise dissapears, then its most likely your throwout bearing
Old 09-13-2007, 03:39 PM
kenlrw39's Avatar
it makes the noise when i rev it in neutral and when i push the clutch in the noise goes away. so your saying it's my throw out bearing are there any other bearing in there that i should check?
Old 09-14-2007, 12:23 AM
estraw's Avatar
no, not without tearing your transmission apart. which believe me, you dont wanna do if you dont have to. but while your in there, if its never been done, you might want to think about replacing your clutch/flywheel/pressure plate too.
Old 09-15-2007, 02:13 PM
kenlrw39's Avatar
ok thanks for the help i'm hoping to begin this sometime next week on one of my days off.
Melvin Cordero Sanchez
07-28-2013 05:06 AM
DriftnROCKER77
04-11-2008 11:40 PM
wildchildgirl
02-22-2008 03:22 AM
jpardinas
10-19-2005 11:30 AM
Quick Reply: were is the fill point on my transmission
