were is the fill point on my transmission
if its in neutral when it makes the noise, its most likely your bearings. if you push the clutch in and the noise dissapears, then its most likely your throwout bearing
it makes the noise when i rev it in neutral and when i push the clutch in the noise goes away. so your saying it's my throw out bearing are there any other bearing in there that i should check?
no, not without tearing your transmission apart. which believe me, you dont wanna do if you dont have to. but while your in there, if its never been done, you might want to think about replacing your clutch/flywheel/pressure plate too.
Melvin Cordero Sanchez
Jul 28, 2013 05:06 AM
jpardinas
Oct 19, 2005 11:30 AM
