WHAT BOOST??
Old Jan 10, 2005 | 03:18 PM
congonator's Avatar
Default WHAT BOOST??
I have a 97 GST with injen style intake and filter, upgraded to big 16g turbo, full 3" turbo back exhaust custom made(no cats)w/straight thru design magnaflow muffler, Apex Super AFCII, Greddy Profec Type S Boost controller. How much boost is available to run efficiently and how much should i run? Could i squeak out a high 11 or low 12 with what i have??
Old Jan 10, 2005 | 08:45 PM
96awd's Avatar
Default RE: WHAT BOOST??
you will not hit a 12 with what you have. you need to upgrade your fuel system before you go turnning the boost up. you should get you a walbro fuel pump at least a 190 then some injectors 550 or 650 will be a good choice. and if you go with the 250 walbro, you will need a afpr. a front mount will help out alot.
with what you have right now i would keep the boost down to around 14-15psi until you get the fuel mods. thats were people make there mistake they get a turbo or a mbc turn the boost way up and wounder why there engines blow up. more air without the fuel to mix with it will cause a lean mix and thats when you start blowing things.
Old Jan 10, 2005 | 10:20 PM
congonator's Avatar
sorry, i forgot to add that i have a walbro 250 but not bigger injectors and no fuel pressure reg.. So i need to add those to those to the shopping list. By the way, it is a bitch to get the boost controller settings just right. Thanks for the info AWD!
Old Jan 10, 2005 | 10:28 PM
96awd's Avatar
yea if you have a 250 walbro you need a afpr first thing. it will over run your stock fpr. i just use a mbc to control the boost cheap but easy.
Old Jan 16, 2005 | 02:09 AM
nate5023's Avatar
You will need the fmic to run full boost but you should be able to run around 21 PSI everday, if you have all the right mods.
anko_kun
Dec 24, 2006 07:48 PM
T76 turbo
Apr 16, 2004 04:53 PM
T76 turbo
Apr 15, 2004 01:02 AM
Pinser555
Mar 5, 2004 10:00 PM
Pinser555
Feb 28, 2004 03:55 PM
