what kind of clutch for 98gst?
RE: what kind of clutch for 98gst?
flywheel: if you are a baller go buy a fidanza, if not buy a stock lightened flywheel from roadrace, theyre like $130, thats what i got
LSD: quaife but they are mad hardcore money, i wouldnt get it unless you are going to build a fast drag car and want to race with slicks, otheriwse its not needed
bushings: you dont need the tranny ones, but get some polyurethane ones that go under the shifter base, they make a huuge difference and are only $10. b&m is the only good shifter for dsms, i have one and love it
starter/slave cylinder: no need to get until they go bad, having the tranny out wont make them that much easier
This is a incompentent question but correct me if im wrong but lightened flywheel is just to make more power to the wheels? So if he is not running a lot of HP why buy a lightened flywheel when a sock one is like $60?
flywheels dont make more power to the wheels, its just less rotational inertia, it makes your engine revv quicker and accelerate easier. it has the same effect as buying lightweight rims. roadrace lightens them from 19lbs down to about 14lbs. fidanzas are i believe only 8lbs. but even the roadrace ones help quite a bit because they take all the weight off around the outer portion of the flywheel, where it makes the most difference. it all goes back to physics
ORIGINAL: DSMTalonAWD51
oh i forgot,i just acquired 2 evo8 rims and tires,i want to run some nitto 555r's on them for track purposes.i am not a hardcore drag racer but just wantto go every so often when i do a mod or i am bored ill head to the track,and just wanna perform well.i figure spinning 3 gears= losing precious time.its a good part of the reason i will be starting an awd spyder project before the year is up.thanks again
