what kind of clutch for 98gst?
Old Feb 1, 2006 | 03:46 AM
DSMTalonAWD51's Avatar
Default RE: what kind of clutch for 98gst?
flywheel: if you are a baller go buy a fidanza, if not buy a stock lightened flywheel from roadrace, theyre like $130, thats what i got
LSD: quaife but they are mad hardcore money, i wouldnt get it unless you are going to build a fast drag car and want to race with slicks, otheriwse its not needed
bushings: you dont need the tranny ones, but get some polyurethane ones that go under the shifter base, they make a huuge difference and are only $10. b&m is the only good shifter for dsms, i have one and love it
starter/slave cylinder: no need to get until they go bad, having the tranny out wont make them that much easier
Old Feb 1, 2006 | 10:34 AM
get435's Avatar
This is a incompentent question but correct me if im wrong but lightened flywheel is just to make more power to the wheels? So if he is not running a lot of HP why buy a lightened flywheel when a sock one is like $60?
Old Feb 1, 2006 | 08:26 PM
flywheels dont make more power to the wheels, its just less rotational inertia, it makes your engine revv quicker and accelerate easier. it has the same effect as buying lightweight rims. roadrace lightens them from 19lbs down to about 14lbs. fidanzas are i believe only 8lbs. but even the roadrace ones help quite a bit because they take all the weight off around the outer portion of the flywheel, where it makes the most difference. it all goes back to physics
Old Feb 2, 2006 | 09:55 AM
get435's Avatar
Ok now it is coming together this is about what i has though on it but not fully compleate thanks for the info DSMTalonAWD51.
Old Feb 3, 2006 | 10:34 PM
badass91hatch's Avatar
ORIGINAL: DSMTalonAWD51
thanks for your reply,i would really like to go with an lsd because at the track i cant buy traction.it spins through 3 gears(well with 19's) at no matter what launch rpm,no amount of clutch feather will calm it down.i dont know why but i had the impression that fidanza was junk,lol sorry bout that ill take your word.and as far as the b&m your right it was the only one i was considering for a shifter.thanks again man
Old Feb 3, 2006 | 10:38 PM
oh i forgot,i just acquired 2 evo8 rims and tires,i want to run some nitto 555r's on them for track purposes.i am not a hardcore drag racer but just wantto go every so often when i do a mod or i am bored ill head to the track,and just wanna perform well.i figure spinning 3 gears= losing precious time.its a good part of the reason i will be starting an awd spyder project before the year is up.thanks again
Old Feb 3, 2006 | 11:45 PM
fidanzas are awesome, no junk there, just not worth the money in my opinion, but i am cheap
Old Feb 4, 2006 | 03:28 AM
thats cool,im an avid ebay shopper and fidanza's are cheaper than ACT flywheels.around $200,i dont think thats too hateful.
Old Feb 4, 2006 | 04:30 AM
then get it, i was under the impresssion it was $350ish
Old Feb 6, 2006 | 08:51 PM
99clipsgst's Avatar
So with the stock clutch It can hold 14 or 15 psi with a front mount worth of power. Im looking to make 250 hp to the wheels.
