What to replace now?
Old Dec 22, 2007 | 02:51 PM
thehintons06's Avatar
Default What to replace now?
Hey on my 98 dodge avernger es 2.0 420a i got a code and it is say that it is code PO340 camshaft position sensor circuit malfunction so im assuming that i have to replace a cam sensor so i was wondering if the avenger has one sensor or two because when i rebuilt me 3000gt sl engine it had 2 sensors also where would the sensor/s be located?
thank you
brandon
Old Dec 22, 2007 | 05:36 PM
Default RE: What to replace now?
there is only one cps and if the sensor is bad usually the car wont even start. You could try and replace it but i would check the wiring to it first. I believe the repair manual wil have a way to check the voltage at the sensor to see if its bad
Old Dec 23, 2007 | 05:42 PM
i checked the volts and the ground was good but the positive only has 2.4 volts so i checked the same wire where it comes out of the pcm/ecu and it is also 2.4 volts so any suggestions? the car wont start
can i hard wire a wire to it?
Old Dec 24, 2007 | 12:27 AM
tx2u's Avatar
Did you just get the code while driving or were you tinkering with some other stuff? BTW, is the sensor clean?
Old Dec 24, 2007 | 12:07 PM
one day i just went out and the car wouldent start so i hard wired it and it is working fine thank you
joeg
18
May 24, 2012 05:29 PM
Lil red
Oct 4, 2005 10:19 PM
dsm16gawd1984
Jul 9, 2005 11:39 PM
jmms
Mar 18, 2005 10:53 AM
bcolins
Jan 31, 2005 02:58 PM
