What whould win gs-t or gsx
Old Feb 25, 2004 | 06:27 PM
nate5023's Avatar
Default What whould win gs-t or gsx
Me and my friends hada argument they said a gsx is faster, but i think a gs-t is is that true
Old Feb 25, 2004 | 10:16 PM
EPSYCHOBOB's Avatar
THE GSX HAS A FASTER TAKE OFF IF YOU DROP THE CLUTCH AT 6000RPM BUT THE GS-T IS FASTER BECAUSE IT IS LIGHTER (0-60 IN 6.5 SEC) BUT THE ONLY PROBLEM IS THE WHEEL SPIN BUT I WOULD SAY THE GS-T IN THE LONG RUN.</P>
-I LOVE THE GSX!!</P>
Old Feb 27, 2004 | 11:35 AM
SpyderGS's Avatar
GST has a speed limiter , GSX doesn't. In a 1/4 the GSX might take a gst because of the awd advantage. Highway, there's no contest. A gst would accelerate quicker.
Old Feb 28, 2004 | 02:09 PM
EPSYCHOBOB's Avatar
BUT ISN'T THEGSX HEAVIER AND JUST THE THE TAKE OFF ADVANTAGE BUT ONCE THE GS-T GETS GOING ITS GONE!
Old Feb 28, 2004 | 03:36 PM
BurntGSX's Avatar
the gsx has the advantage everywhere except the hwy/interstate. for the reason that it is heavier. if we're talking stock vs stock...1/4's might be close, with the GSX. mainly the fact of wheelspin and GST's have bad launches. just the way they are made. the gsx will be a car length ahead out of the start, and stay there because the run isn't long enough for the weight difference to be affected.
Old Feb 29, 2004 | 05:24 PM
nate5023's Avatar
so ru saying the gs-t has a governor, and cant u get a ecu chip for that?
Old Mar 1, 2004 | 01:16 AM
BurntGSX's Avatar
not sure if the chip will do anything, except empty your pocket. they are expensive, unless you have a 95 or 96. otherwise you need to switch out the whole ECU? ( correct me if im wrong ) but there is something pretty major to just ADD a chip. unless you send your whole comp in, but then no driving for up to 2 weeks.
Old Mar 1, 2004 | 02:05 PM
SpyderGS's Avatar
TMO supposedly made a chip for the ecu, but why buy a chip? check the VFAQS for a FREE mod to remove the speed governer. PEOPLE, YOU CAN FIND EVERY AND ANYTHING YOU NEED ON DSMS IN THE VFAQS!!!!FOR FREE!!!!
Old Mar 1, 2004 | 02:10 PM
SpyderGS's Avatar
Also, the awd system takes up power. Remember, it's *full-time awd*, it never stops working or cuts off no matter how fast you are going. On 1g, drivetrain loss is about 15% for fwd. On AWD 1g's the drivetrain loss is close to 25%. So with a fwd, you'll put more power to the ground instead of using it to spin dead weight. I'm not too sure if the same ratio is used for 2g's, since the tranny and rear-end is way different than a 1g.</P>
Old Mar 2, 2004 | 12:59 PM
toaster_power's Avatar
...so its better fwd for race?
