What Is wrong with my car????
Ok, so heres my problem.
I get a check engine code that comes up every once in a while and when I get it checked at Autozone the possible causes say it could be a vaccuum leak wiring problem idle air control valve But I was wondering since it is the turbo version if it could be the intercooler piping as well. I'm not a big car guy but my brother and all his friends are and they say the pipes look corroded and need to be replaced. When I drive I can drive fine unless I really punch it in which it sputters like a spark plug is out. I have changed the all the spark plugs and the wires. I'm just wondering what can I do to fix this and if it is the piping or something else. I have also cleaned the Idle air control valve hoping it would fix it but it didn't. The car also idles low or high at times and sometimes when I shift the idle will go so low it'll either turn off completely or just for a brief second. Any suggestions and help would be great! I have a 98 gs-t |
sounds like a boost leak to me. You can pickup a boost leak tester pretty cheap and test your system. Do a search on here since there have been numerous threads on how to do this. But that would definetly be my guess. Alot of times its the couplings/clamps on the IC pipes. Or the POS stock BOV
thanks, I'll check that out
I'm w/ TE check for boost leaks, the throttle body shaft seals and fuel injector insulators are 2 very common areas for boost leaks.
good luck with the boost leak if its the probelm,, im still trying to chase mine down,, waiting on the dejon lower I C pipe
but look on my last post and they gave me a couple good sites to construct a boost leak tester |
