when is it time for a walbro?
Old Dec 12, 2007 | 08:36 PM
BoostNightRanger's Avatar
Default when is it time for a walbro?
Just wondering, how much boost can you push (generally) on a dsm before you need to upgrade your fuel pump? And secondly how much boost can the 2nd gen turbo make(T28?)
Old Dec 12, 2007 | 08:48 PM
bestwiseguy's Avatar
Default RE: when is it time for a walbro?
The t28 can push between 14-15 psi. You do not need a bigger fuel pump on the stock turbo, but as soon as you upgrade it wouldnt hurt to get a new fuel pump. But you will also need a wideband gauge and safc2 to tune it with.
Old Dec 12, 2007 | 08:51 PM
When you want to go past 17 you need a walbro. If you only plan on running like 23ish on a 16g, then you will only need a 190lph, if you want to run more, and on a bigger turbo,then you will need a 255lph with a fuel pressure regulator.
Old Dec 12, 2007 | 09:22 PM
alright awesome, how safe is it to turn the stock turbo up to ballpark 14psi?
Old Dec 12, 2007 | 09:55 PM
sk8dudety's Avatar
yea you'll be absolutely fine at 14
Old Dec 12, 2007 | 10:07 PM
The safety limit for that turbo i would say is at 19, although 17-19, you really arent going to experiance a lot of gains, but its still nice to have. On stock fuel, 16psi is where you should be at.
Old Dec 13, 2007 | 06:41 AM
ORIGINAL: BoostNightRanger
am i the only one that caught this. Its a T25. I know Boostnightranger was asking...but bestwiseguy reiterated it .
Old Dec 13, 2007 | 07:21 AM
Oh **** my bad i didnt even notice it. Thanks for pointing that out TE.
Old Dec 13, 2007 | 11:08 AM
ya i couldnt remember if it was the T25 or the T28, if its the T25 then isnt the T28 the newer version of that turbo?
Old Dec 13, 2007 | 11:10 AM
It is just a bigger version of the t25.
