where does evryone....
Old Dec 25, 2006 | 08:09 PM
racerx55's Avatar
Default where does evryone....
where does evryone run all the guage wires / hoses & crap through the firewall? my neon had holes & plugs to remove evrywhere, i'm lucky i can evn see the firewall on this car
i cheated and ran the boost guage linearound through the door for a temp. hookup
i suppose im gonna have to drill a hole
Old Dec 25, 2006 | 09:11 PM
TheAdvocate's Avatar
Default RE: where does evryone....
I had to drill through it on mine..
Old Dec 25, 2006 | 10:49 PM
paintballproam's Avatar
under the top part of the fender and in through the a piller
Old Dec 28, 2006 | 06:33 AM
98eclpsrider's Avatar
I put mine through a hold in the firewall just behind and a little to the left of the the wheel well looking down in the engine bay, and then up throught the dash and into the apiller, and for the power i daisy chained them together and go the power from my cigerette lighter since it had ignition on/off power.
Old Dec 28, 2006 | 07:09 AM
silvercoupe97's Avatar
Most folks just slit the steering shaft boot for the boost gauge hose, that's what I did. No, it hasn't or doesn't bind on the shaft at all. You don't slit close to the shaft, slit it about an inch from the shaft. The wires can go through the same hole too if you have any gauge sensors that need to connect back inside. My wideband wiring went through the passenger side (stock ) wireharness boot. That's a 2G though, I don't know if the 1Gs have that same area opened up for the wiring.
As for the power/light wiring, something like 98eclpsrider did or whatever. My gauges are on the instrument cluster bezel too.<--- I forgot the signifcance of that, but...., lol.
Also, if you do drill a hole, the steering shaft area is a good place because you're able to move around and more importantly, get a drill in there. That, and you're also able to reach behind the motor to get all your wiring/hose.
Old Dec 28, 2006 | 06:36 PM
93eclipsegsx's Avatar
yes the 1g is the same b/c i had it done on mine but since i had the motor out since i blew it up i drill holes for the boost gauge and the EBC so it looks better.
GRIDLOCK
Feb 28, 2004 03:57 PM
XLR8N_GSX
Dec 19, 2003 06:56 AM
romeo
Oct 2, 2003 07:00 PM
Yargk
Sep 14, 2003 06:42 AM
shane82786
Jul 2, 2003 01:17 AM
