Where take the signal of a eclipse 99 GST to plug a Megasquirt ?
Old Sep 6, 2007 | 07:40 PM
Powertech's Avatar
Default Where take the signal of a eclipse 99 GST to plug a Megasquirt ?
Hi to everyone I need a little tip here. If any one in these page have work with a Megasquirt system?I want to know from where to take the signal to read the timing if I can take it from the cam trigger or from the distribuitor?Is a eclipse turbo GST.
Old Sep 6, 2007 | 09:01 PM
Kaede.Noir's Avatar
Default RE: Where take the signal of a eclipse 99 GST to plug a Megasquirt ?
Megasquirt? sorry not familiar with the term, but if you tell us what it is it could be easir to identify (too lazy to google, and if i do im sure ill find some weir wet ****)
Old Sep 6, 2007 | 10:40 PM
get435's Avatar
Q. What is MegaSquirt?
[blockquote]
A. MegaSquirt is intended as an educational project for those who want to learn about electronic fuel injection. It is an experimental Do-It-Yourself programmable electronic fuel injection controller that you build yourself. MegaSquirt will work on virtually any liquid fueled spark-ignition engine, naturally aspirated or boosted (up to 21psi boost with the standard MAP sensor). Note that MegaSquirt is the controller only, you will have to gather the remaining fuel system parts yourself (from 1 to 16 injectors, sensors, fuel rails, fuel pump, etc.).
This was found at http://www.megasquirt.info/
This looks like some cool stuff think ill read into it.[/blockquote]
_Adrian_
Jan 22, 2012 03:17 PM
edster1
1st Generation
Aug 20, 2010 05:07 PM
Russianfart
Feb 4, 2008 01:07 PM
dsmbuilder
Jul 17, 2007 12:33 AM
spyder4g63t
Oct 30, 2006 09:07 PM
