white smoke
Old Nov 4, 2007 | 09:25 AM
clips69's Avatar
Default white smoke
what are some causes of alot of white smoke coming out of the exhaust...seems like im burnig up antifreeze...but not sure how or why...good news though ive finished my 2.4l dohc turbo!!
Old Nov 4, 2007 | 11:19 AM
jlh077464's Avatar
Default RE: white smoke
Usually that means Your headgasket is about to blow or has already.
Old Nov 4, 2007 | 11:52 AM
TheAdvocate's Avatar
Ya.. You will also be able to smell it..
Old Nov 4, 2007 | 12:42 PM
antlip's Avatar
Head gasket or your head has a problem. Did you run it hot or over heat?
Old Nov 4, 2007 | 02:04 PM
estraw's Avatar
check your oil to see if it looks really bubbly. if your headgasket is gone your oil will most likely look like a frothy capuccino
Old Nov 4, 2007 | 04:41 PM
nick_200321's Avatar
also the oil MAY be white, not always, and if it is the head, you will probably have low oil pressure
Old Nov 4, 2007 | 05:02 PM
sk8dudety's Avatar
yea check under your oil cap and see if it's got any white goop in there
Old Nov 4, 2007 | 06:34 PM
clips69's Avatar
yea it has some of that stuff your talking about.....any chances of it might being the water pump?
Old Nov 4, 2007 | 06:38 PM
sk8dudety's Avatar
nah, headgasket bro
Old Nov 4, 2007 | 10:15 PM
antlip's Avatar
Your better off with a head gasket than water pump issue.
