White smoke GST?
seems like ur rings are bad and whiteish "blueish" smoke is about the same thing i was gonna say valve seals, but with that compression test,and correct me if i wrong, the compression should be the same all the way around so the rings could be letting oil get in the combustion chamber. that and the valve seals with that much mileage u want to do it anyways
it's 1 of 2 things.... either a blown ring or blown head gasket. the 420a's are NOTORIOUS for blowing head gaskets and even more so for blowing them in the #1 cylinder. sounds like a bad HG to me....
if you can afford it maybe just swap out the motor with a rebuilt one or even a new one. i know my 4g63 was beat to hell before i bought it and blew up hopefully you dont have that problem. mine was a headgasket leak that turned into a nice 4000 dollar repair. just trying to give u some more ideas
ORIGINAL: atown420
