Why is my GSX so slow?
Old May 26, 2008 | 04:06 PM
ProjectDrknss's Avatar
Default Why is my GSX so slow?
Would the fact that my GSX is an auto make it sooo slow? I run the 1/4 in about 17 sec. Is that normal for a/t GSX? Everything is stock cept for exhaust and intake filter. I'm also boostign about 12 lbs. My cousins civic is having better times than me and his is a Sohc V-tec.
Old May 26, 2008 | 04:50 PM
sk8dudety's Avatar
Default RE: Why is my GSX so slow?
my rs used to run a 17 flat... you sure you dont just have a gs and are in denial?
Old May 26, 2008 | 05:24 PM
I bet if you are running the stock BOV that is slowing you down a little.
Old May 26, 2008 | 05:30 PM
ORIGINAL: Sebba
yea but not 17 sec slow.
Old May 26, 2008 | 05:32 PM
True... must be a MAJOR boost leak + bad driving + auto tranny handicap.
How did you launch the car?
Old May 26, 2008 | 05:41 PM
lol i DO NOT own a gs. i also know it's a gsx cause i've looked up the car's number. for the leak, i dont think im leaking because i have a boost gauge set up. it boost 12 everytime i throttle it and stays at 12 until i release the gas. when i launch, i hold the brake and rev to about 2.5-3k rpm and when it's go time, i smash it right after releasing the brake.
Old May 26, 2008 | 05:56 PM
Thats really odd then....
Old May 26, 2008 | 08:11 PM
how are you reving an auto that high. Stock Stall is like 1500-1800 or something like that. so you can rev highing while in gear. if your putting it N to rev and dropping to drive then that is your problem
would dyno-ing the car help in anyway at all?
Old May 26, 2008 | 08:13 PM
No not really.
