Why is my GSX so slow?
Old 05-29-2008, 04:01 PM
silvercoupe97's Avatar
Default RE: Why is my GSX so slow?
There could be a combination of things at play here. Boost leak, plugs, wires, o2 sensor, too much hot air forced down the chambers (too much oil in the stock I/C), and so on. It's not really a clean cut answer to your question.
17 seconds is not good for a turbo DSM, even for an auto which rates close to a manual in times.
Did you get FP to rebuild the turbo into a Big28? If so, your car is dead slow. Even at 12psi, there is a big difference between the t28 and big28.
No one has suggested it yet, so I will suggest for you to do the normal stuff such as a boost leak test, replace plugs and wires, clean I/C to include the piping, change your oil, PCV valve (could cause a slight increase in positive pressure in the head), and so on.
Maximus99
09-16-2017 07:23 PM
jpmontero98
10-01-2008 06:13 PM
darknigh7th
03-28-2008 05:20 PM
jpmontero98
08-31-2007 01:39 PM
twistid_desirez
03-27-2004 01:05 PM
Quick Reply: Why is my GSX so slow?
