Wideband install
Old Feb 21, 2008 | 04:55 PM
bestwiseguy's Avatar
Default Wideband install
I just purchased a aem wideband from a fellow member here. Where is the best place to weld on the 02 bung for the sensor?
Old Feb 22, 2008 | 09:29 AM
Default RE: Wideband install
BUMP!! Come on guys, surely one of you knows the answer lol.
Old Feb 22, 2008 | 10:03 AM
most of the time youll have it on the test pipe (assuming you have one). The general idea is to be in that area. Yuo dont want to be too close to the turbo, but you dont want to be too far away either
Old Feb 22, 2008 | 11:14 AM
alright thanks TE. Dont you also have to have it at a certain angle, like 10 degrees or something?
Old Feb 22, 2008 | 11:21 AM
Yea actually to be exact here are the two things to keep in mind when locating
1. Keep the sensora minimum of 3' from the exhaust side of the turbo.
2. Weld at a minimum 10 degree angle upwards so that on cold starts you will not have condensation building up around the sensor
Old Feb 22, 2008 | 11:30 AM
Again thanks TE, just want to make sure i install it right the first time .
Old Feb 22, 2008 | 02:59 PM
anko_kun's Avatar
thats good 2 know
Old Feb 22, 2008 | 04:59 PM
jlh077464's Avatar
That member would be me...lol...but you should post some pics up that will show people on ther future installs.
Old Feb 22, 2008 | 05:26 PM
ORIGINAL: jlh077464
Good idea, i think ill do that. Ill also make a walkthrough for the neo when i get that installed .
Old Feb 22, 2008 | 11:45 PM
jlh077464's Avatar
If you search afc neo under my author name...there is a site that someone posted with a coplete walkthrough with a pic of every step.
