wiring harness compatibility??
Old Feb 7, 2009 | 06:35 PM
jerusry's Avatar
Default wiring harness compatibility??
hey guys, i just need to find out if a 96 talon fwd turbo- fusebox to engine, and ecu to engine wiring harnesses will work on my 95 eclipse gsx? if anybody could shed some insight on this it would be much appreciated.
Old Feb 7, 2009 | 07:33 PM
dsm1990gsx's Avatar
Default RE: wiring harness compatibility??
I would say they would be different since the 95 is obd1 and the 96 is obd2.
Old Feb 7, 2009 | 08:39 PM
jerusry's Avatar
95 is obd1? i thought it was 2 even tho it had an eprom ecu in my car. so that a real bummer. so the fwd/ awd or talon/ eclipse is not a problem. it is more about it being a 95? so i would only be able to find one off a 95? are you sure it is obd1? cuz that would at least boost my chance of not worrying about smog whatsoever..
Old Feb 9, 2009 | 07:20 AM
95 is OBD2. I had a 95 talon AWD and it had the OBD2 port. I dont really see why the harness would be different
Old Feb 9, 2009 | 10:35 AM
jerusry's Avatar
okay, so its obd2... well, i guess i am at least luck enough to have a buddy that will pass me on the visuals and i don't have to hop onto the obd2 dyno since its awd... but that would be nice if the eprom made it obd1. so even tho his is fwd and mine awd they should still be the same. well, i guess i will get the harnesses then. if that is the case. i just don't want to buy harnesses that will not be compatible.
Old Feb 9, 2009 | 11:49 AM
dsm1990gsx's Avatar
Some cars started obd2 in 95 but 96 was the first yearfor obd2.
Old Feb 10, 2009 | 09:34 AM
jerusry's Avatar
well, i am kinda stuck then.... so which one is it? do i need to go to the dealership to ask them or something to make sure? because i have no way of telling who is right... sice both of you have been right when helping me with alot of other things..lol my eclipse is a 95 eprom... thats what is keeping me confused. along with you two having different answers.
Old Feb 10, 2009 | 11:53 AM
dsm1990gsx's Avatar
I would contact the dealer and see if the part numbers for a 95 are the same as a 96.
Pokerdude
Oct 1, 2006 07:51 PM
Mac_attack769
Sep 6, 2006 04:41 PM
AllThingsDSM
Feb 8, 2006 01:33 PM
Reddragon06
Jan 24, 2006 01:43 PM
denied
Feb 9, 2005 12:16 AM
