wonder if somebody can help
Old Sep 13, 2009 | 09:57 PM
c577's Avatar
Default wonder if somebody can help
i have a greddy rs bov and e316g on a 2g gst. i posted earlier about needing a tune and i have a fpr and safc2 on the way but i thought id play around with the car a lil.
k so here is what it has been doing, up until about 4k rpm, whenever the turbo starts to spool, it actually bogged the car down a bit till it hit 4k and then after that it would run great. well idk wat happened but earlier today it started completely losing power until 4k, almost like the bov was letting off early. i didn't see any boost leaks when i checked so im kinda confused about what happened, does this sound like anything other than a boost leak???
my friend said my stock injectors might be peaking out, even though im sure this makes basically no sense since it gets better after that rpm, i put my 550s in there anyways for fun, hey it only takes ten minutes so why not try it out. k well i did that and now instead of losing power until 4k, it pretty much shuts down completely whenever it starts to boost, even as low as 1 psi it just sputters and the car pretty much just coasts. I'm pretty sure there is something else wrong with the car other than just needing a tune, please get back to me as soon as possible. putting the stock injectors back in until i figure out what this problem is.
also the cel is on for fuel trim, which i was told was because the bigger turbo.
Old Sep 14, 2009 | 09:32 AM
well you really really need a Wideband in that car otherwise you could be doing damage and not even know it. You may be running too much boost or too lean. Also you may have bad ignition. Or it could be a boost leak.
Old Sep 14, 2009 | 01:48 PM
c577's Avatar
i will get one as soon as i can, whenever my egt gauge and my afc come in im going to have the speedshop dyno tune it.
Old Sep 14, 2009 | 05:55 PM
dsm1990gsx's Avatar
Put the stock injectors in, the 550's are gonna make the car run pig rich. How much boost are you running? Did you do a boost leak test?
Old Sep 17, 2009 | 06:08 PM
c577's Avatar
ya lol i put them in pretty much immediately after i put the 550s in, im runnin 10 pounds. an yes i did a boost leak check and it checked out fine, i think it was my bov but its fine now. BTW i just got my new glowshift egt boost and oil pressure gauges in they look sexy, also got my fpr and safc2 in today happy me.
could definately use help puttin the safc2 in my car, i think im going to take it to a speed shop and let them handle it but if its easy then id like to do it myself and save the 100 bucks lol...
Old Sep 17, 2009 | 06:35 PM
dsm1990gsx's Avatar
The is a write up on www.vfaq.com for the safc, its not hard to do.
Old Sep 17, 2009 | 06:44 PM
c577's Avatar
actually i think i might have bought the wrong thing D:
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWNX:IT
it says safc but i think its a vafc, will this work for my car or am i screwed???
Old Sep 17, 2009 | 07:05 PM
dsm1990gsx's Avatar
Its the same thing, you paid $170 for an safc I? You can get them used for $75.00.
Old Sep 17, 2009 | 07:07 PM
c577's Avatar
didnt know where to shop, oh well... itll get the job done and that's what i really care about..
Old Sep 17, 2009 | 07:09 PM
dsm1990gsx's Avatar
Damn that sucks, what else are you looking for?
