wont start
Old Oct 18, 2006 | 03:40 AM
jsawyer's Avatar
Default wont start
okay i just bought a 95 gsx when i got it home it wouldnt start all it did was putt putt and miss fire so i check the timing belt and it all checked out so i checked the fireing order it was wrong so i changed it and then i got noting i wouldnt kick over i checked for spark and its good checked for fuel and it was good so i am stumped i have no clue what is wrong with it so if anybody could help me with any sugestions on what could be wrong with it please help it has the 4g63 turbo motor in it
Old Oct 18, 2006 | 10:42 AM
Default RE: wont start
Check the timing belt.
Old Oct 18, 2006 | 12:46 PM
ORIGINAL: jsawyer
ORIGINAL: Sebba
wow....
are your cam gears in the right position, maybe you skipped timing.
Old Oct 18, 2006 | 12:47 PM
Damnit what the hell is the matter with me.
Thats what i meant anyways. Check that it hasnt jumped
Old Oct 18, 2006 | 10:31 PM
jsawyer's Avatar
no they havent jumped every tining mark lines up
Old Oct 18, 2006 | 10:33 PM
ECU maybe?
Old Oct 18, 2006 | 10:46 PM
Nubiebubie_GSX's Avatar
Well if u were able to drive the car home then i really doubt its ur firing order. If a 6 bolt swap was done to the car and there a 95-96 ecu being used, the firing order has to be swapped for the car to run. Maybe that was why it wasn't in stock set.
Old Oct 18, 2006 | 11:22 PM
jsawyer's Avatar
what would the fireing order be if the car had a six bolt swap done on it
and i had to get the car towed home
Old Oct 18, 2006 | 11:25 PM
jsawyer's Avatar
what is a six bolt swap anyways
Old Oct 19, 2006 | 12:45 AM
jsawyer's Avatar
can anybody tell me what the fireing order might be if my car had a six bolt swap
