It Wont Start.....HELP!!!!
Old Aug 7, 2008 | 02:37 AM
DCN2TWEEK's Avatar
Default It Wont Start.....HELP!!!!
ok here is what happened my brother forgot (somehow) to refill his radiator and took off down the road the temp gauge peaked and the car turn it self off now all it does is turn over but wont start what could this be?
Old Aug 7, 2008 | 03:13 AM
silvercoupe97's Avatar
Default RE: It Wont Start.....HELP!!!!
Check the radiator temp gauge, it may be fried.
What model does he have btw?
Old Aug 7, 2008 | 11:15 AM
DCN2TWEEK's Avatar
its a 1998 gs
Old Aug 7, 2008 | 11:44 AM
dsm1990gsx's Avatar
Have you checked the basics...fuel, spark, compression?
Old Aug 7, 2008 | 02:09 PM
needsagst98's Avatar
sounds like he warped the head?. or head gasket went. if it just turns over and doesnt start. that happened to my old one. well gasket broke and wrped the head. it would turn over and took about 10 min to start and it would eventually start. when u filled the radiator up is white smoke coming out the exhaust?
Old Aug 7, 2008 | 03:38 PM
dsm1990gsx's Avatar
He wont see smoke if the car wont start.
Old Aug 7, 2008 | 06:08 PM
DCN2TWEEK's Avatar
we havent been able to get this started yet but we are gonna try it this weekend im hopeing its something small like a sencer or something and praying its nothing big
Old Aug 7, 2008 | 07:32 PM
If he pegged the gauge and still drove it, it will most likely be a warped head as Needs suggested. But there's still a chance that the temp sensor is keeping it from starting (safety feature).
Old Aug 8, 2008 | 02:45 AM
DCN2TWEEK's Avatar
ok well hopefully its only the temp sensor because we are highly starpped for cash if not it will be on craigs list grrrr the dsm strike our pockets again i had a 1st gen......7 bolt that should explain all lol can you say crank walk lol
Old Aug 8, 2008 | 07:55 PM
Joel_CA's Avatar
ORIGINAL: silvercoupe97
When i worked for Mitsubishi, I've seen failed coolant temp sensors prevent startup due to incorrect readings (on the 2.0L DOHC 420A engine)- but never as a safety feature. The failed sensor basically tells the PCM that the engine is at sub 0 temperature resulting in an instant flooding upon startup. This was a common problem because the upper radiator hose was a common leak source and it always leaked onto the temp sensor corroding the terminals.
Back to the original post- start with a compression test. I'm certain this will expose the root of your problems. Likely a blown headgasket and .. depending how hot it got- a warped cylinder head. Note that the 420A cylinder head cannot bemilled and will need to be replaced.
JJ
