03 Eclipse RS - Cold Air Intake
you want a Carb exempt(50 state legal) one or a one just as good for a fraction of the cost?
Carb exempt- AEM Check their website out
Alternative-Go to Kragen or autozone and get a intake kit 15-20 bucks. or Ebay I guess. But the Legal Carb exempt 50 state way is AEM (the price is all for the silver sticker 0_o
DO NOT BUT FROM EBAY. Another thing I have had expeirence with in these cars. The cheap intake can actually cause your throttle body flange to crack and snap off. I had it happen to mine 4-5 times before I figured it out. replacing an intake manifold is not cheap. After that I made the switch to Injen. AEM is also very good.
Note this is only true on the RS/GS 4g64 motor. I never ran a cheap intake on any of my GTs.
pipes....if your flange cracked Then it was either already weak or you over torqued it, alway look up the torque spec's....No offense man im a mechanic I deal with alot of this stuff on a daily basis.When I run my civic I run a straight pipe from mani to right headlight with gravity tunnel on end. My 69 chevelle has a Edelbrock 20 bucks -Kragen brand one.
FYI I had mitsu techs even working on the car after I had swapped the intake Mani twice myself. Mitsu did the next one and still did not fix the issue because even mechanics who deal with this stuff on a daily basis could not prevent it from happening twice more.
To the OP take my advise DO NOT buy and intake on Ebay unless it is a REAL thing otherwise you will pay for it later and then some if you do.
Depends. You can buy a kit used too and just pick up a new filter and be done with it. I bought my Injen intake for my old GT for $110 used and another $40 for a new injen filter. Brand new they are in the $200 range.
I would only look into KnN, injen, or AEM. They are the safest bet. Just remember CAI put the intake low to the ground and you cant drive through puddles
