2000 Eclipse electrical nightmare
I just bought a 2000 Eclipse from my buddy 2.4L 5-speed with a rod knocking going to pull the engine and have it rebuilt but it also has a few more problems. The headlight wire ends burned up a few years ago and the are really dim. The passenger side window motor also burned up and if you don't pull the negative battery cable the battery will die. You can also pull the window fuse in the engine compartment. I unplugged the burnt motor but there is still a draw in the fuse box so there has to be a short but where should I start looking. One last thing before the engine started knocking the car was a pain to drive because you had to hit the clutch and rev the motor to keep it running when you need to stop. Does anyone have any solutions??? Or know where I can get some??
RE: 2000 Eclipse electrical nightmare
Good luck!
Joel, CA
