2001 Eclipse Catalytic Converter on 2000 Eclipse?
Old Jan 9, 2011 | 08:35 PM
kashmiriomar's Avatar
Default 2001 Eclipse Catalytic Converter on 2000 Eclipse?
hey im interested if knowing if i were to change my 2.4 engine eclipse catalytic converter ....would a 2001 2.4 engine catalytic converter fit?
thanks
Old Feb 8, 2011 | 11:21 AM
FireRdyAim's Avatar
well it depends really because emmisions regulations went up in the middle 2000 around june (im not sure which month exactly) in the US, so depending if the car was made the months before june then the 2001 catalytic converter would not fit. However if it was made after june, it should. Check the VIN number on your car to see when exactly it was made. im not sure of a site that tells you the codes though. So just make sure you do the research before tearing it up =) Good luck.
havoc88
Sep 16, 2014 03:26 PM
Ricklagomarsino
Feb 13, 2013 09:39 AM
bishops223
Dec 27, 2007 12:34 PM
FatalJRA
Oct 26, 2004 02:46 PM
