2001 Gt Eclipse Ac compressor shuts off
Old Aug 11, 2012 | 09:34 PM
Footlead's Avatar
Default 2001 Gt Eclipse Ac compressor shuts off
I just installed new ac compressor and tensioner and belt. The ac was pulling down to 38-42 degrees in 99 degree heat. Drive the car for about 10 minutes and the compressor shuts off and the green light starts blinking on the ac /fan selector switch inside. What is the deal. Clutch disengages or compressor shuts down for high pressure or what. My a/c gauges look good and she blows cold until you drive down the road and then all of a sudden it shuts off and will not come back on until the thing cools off the ice cold again. Mitsubishi is about to **** me off.
I already fixxxed the evaporator drain plug problem that plagues these cars. The engineer needs his head slapped that designed that drain design.
Old Aug 12, 2012 | 08:42 PM
mxmikie's Avatar
what are your pressure readings ???
Old Aug 12, 2012 | 10:43 PM
Footlead's Avatar
Well all i have is a auto parts freon install gauge that tells you if your low or full or over full. It reads good. Dont have good gauges that actually read the pressures.
Reformed1
Jul 18, 2011 06:27 AM
1997gsstock
Mar 4, 2010 07:41 PM
crashbandit175
Jun 29, 2007 12:08 AM
oriental_express
Mar 3, 2006 10:20 AM
Kaeslice
Feb 15, 2005 01:26 PM
