2002 eclipse idle problem, hard start, loss of power on acceleration
Old Dec 6, 2018 | 08:49 PM
02mitsuecli's Avatar
Default 2002 eclipse idle problem, hard start, loss of power on acceleration
I have been messing with my car for 6 months now have been to multiple mechanics and no one can figure it out. I can not figure it out. Have replaced a lot and done a lot. Replaced MAF sensor, tps sensor, both 02 sensors, fuel pump, map sensor, egr valve and checked for vaccum leaks.
Old Jan 20, 2019 | 07:05 AM
Widgmaster's Avatar
Sounds like you tried all there is to do … I would like to point out that there is a check ball in one of your vacuum lines going to the EGR Valve... Some times it can get plugged . There are two small lines ( three or four inches long ) feel these and try to locate the check ball.. remove the line and some how clean it out with a cleaner that wont hurt your rubber line.. May not be the problem but worth a try . Hope this helps
V6Mivec
Aug 27, 2015 04:23 PM
Donas
Apr 14, 2014 01:20 PM
Mikee
Jun 28, 2011 12:07 PM
Fullysickmitsu
Dec 4, 2007 06:52 PM
VR4Restored
Aug 14, 2004 01:09 AM
