2003 Eclipse RS Brake Drum Removal ??
Old Jul 28, 2006 | 09:03 PM
atari_400's Avatar
Default 2003 Eclipse RS Brake Drum Removal ??
Hi there, I want to change my read drum pads but am not sure how to release the drum.
After I remove the wheel how do I remove the drum ?
Looking at the online manual I cannot see anything that retains it.
Do I need to carefully knock them off or is there something else I need to do to release them ?
Thanks.
Old Jul 28, 2006 | 09:13 PM
estraw's Avatar
Default RE: 2003 Eclipse RS Brake Drum Removal ??
take a rubber mallet and hit it around the sides of the drum, be gentle but not too gentle. this should knock it loose after a bit. they just get corroded i guess and that along with the heat makes it stick
Old Jul 28, 2006 | 10:16 PM
atari_400's Avatar
Thanks !!
A trip to the dollar store to buy a rubber mallet, a few taps and the drum is off !!
Any idea how to undo the main spring ?
Thanks in advance.
Old Jul 29, 2006 | 12:40 AM
Joel_CA's Avatar
Drum brakes generally last a VERY VERY long time. Unless you're less than 2mm remaining, your shoes should still be good for a long while. Drum brakes uses very high tension return springs. Unless you have the tools AND the experience to do the job, i suggest you take it to someone qualified or have someone qualified guide you in person.
Joel, CA
Old Jul 29, 2006 | 02:54 AM
atari_400's Avatar
Well, the drum pads look to have just as much pad material on them as the new pads. Therefore I didn't bother replacing them (especially as I could not get the spring off).
However, that still begs the question, what is the squeaking noise I hear when I gently apply the brakes at slow speeds ? The drums felt perfectly smooth inside with no pitting or scoring.
Old Jul 29, 2006 | 10:38 AM
estraw's Avatar
ya know, i had the same problem and the shoes didnt look warn at all, however i replaced them and they worked perfectly with no noixe, so idk, try it anyway... as for that spring problem, a simple pair of vice grips to grab it and get it off should work, thats what i did anyway
Old Aug 4, 2006 | 12:51 AM
atari_400's Avatar
Thanks.
Actually, I think that just emptying the dust out of the drums got rid of the squeal !!
mrbndcksaint420
Sep 3, 2010 02:02 PM
TinkerMan
Nov 15, 2006 11:46 PM
Thirdorb
Feb 12, 2006 04:01 PM
theduke1959
Jan 16, 2005 11:41 AM
sik_chode
Jan 5, 2005 08:52 PM
