ARGHHHH!!!!
ok, i just replaced my front brake pads and they work just fine, only problem is that when im goin 40ish mph and i use the brakes, the steering wheel shakes real bad, and if im goin faster than 40 then the whole car shakes when i use the brakes. WHAT THE HECK IS GOIN ON????
thanks
thanks
get your tires balanced. If that doesnt help, then you might have some slight warpage on your rotors, which can be fixed by a machine shop, or I would personally go to napa, who happens to have a machine shop.
well i might end up gettin new tires soon, so the balancing can probably wait, my valve caps on my tires are refusing to come off, and my tires are low, so im kinda outta options with that, i tried wd40'ing them and using vicegrips and pliars and all that good crap and it seems like someone epoxied them on there, so... yeah[:@]
