Boosted 4g64's, who's got em, I need info!
Ok, so I've been looking into a swap for my car recently, and apparently, the 4g64 will fit with minimal modification. Now, I could keep things simple and just do a header, exhaust, CAI, maybe MSD ignition and a few other bits and pieces and call it a day, but I like turbos:D. So here's a couple question I had, and hoped you guys could answer:
1.) I'd like to be running a t3/t4 hybrid turbo on about 7-9psi. Will the motor support that much boost on stock internals? 2.) Say I do manage to run between 7-9psi, what size injectors would I need, and where would I source them from? 3.) What sort of reliable power does a boosted 4g64 make on said boost? I'm sure I'll have more questions as the time draws closer, and as people present information. I've never done a swap before, so this is all pretty new to me, so I'm taking things slow and making sure that I've got all my facts straight before I go and start buying parts. |
RE: Boosted 4g64's, who's got em, I need info!
The 4g64 is a very good motor for boosting. So if you get one from a broken down 3g. Then they can run about 10psi on stock internals with the t3/t4, which is what most people run on those. And i know that alot of people run those cars daily with a turbo kit without problems. Your best bet is to check out www.tearstone.com and club3g for some really good info on this, or emonz because he's knows aaaalllllll about this ;)
Yeah EMonz is your man.
