Crank but no start after changing plugs & wires
Old Apr 3, 2013 | 10:29 PM
pinstripe's Avatar
Default Crank but no start after changing plugs & wires
I have a 2001 Mitsubishi Eclipse GT with the 3.0L V6 5 speed and just finished changing the plugs, wires, valve cover gaskets and upper intake gasket, I also put in a new battery. Paid attention while taking it apart and back together so I thought but now it won't start. The engine turns over fine, has fuel but not sure if it has spark yet. The OBD2 code says EGR transducer open or shorted. All connectors are connected as far as I can tell. Am I missing something with this EGR thing? Any help or pointers would be appreciated.
Old Nov 16, 2015 | 02:16 PM
ricardohd91's Avatar
Check around the manifold, make sure you didn't catch a wire or something like that, could be causing a short in the EGR circuit. Almost all sensors require a 5 volt reference, so if that 5 volt is grounded, nothing with work.
Jonv420a
Nov 28, 2012 03:19 PM
Jonv420a
Nov 28, 2012 02:43 PM
boostedmuscle22
May 6, 2012 02:06 PM
ehawk24
Nov 29, 2008 11:31 PM
Tom97rs
Nov 12, 2003 07:58 PM
