door windows gets stuck on upper pillar
Old Oct 2, 2008 | 01:06 PM
rkfguard's Avatar
Default door windows gets stuck on upper pillar
i just bought a 2003 eclipse rs and when i have the window rolled all the way up, i cant open the doors on either side..they are power windows. is there an adjustment or fuse that may have blown..i noticed on the 2006 and newer eclipses that when you open the door handles, the window will automatically open 10mm to allow you to open the door,, does the 2003 have the same operation,,if so..what would i need to check or do to fix it..thanks ahead of time
Old Oct 2, 2008 | 04:52 PM
estraw's Avatar
Default RE: door windows gets stuck on upper pillar
no thats a new feature. i didnt even know the new ones had that. your saying if the windows down a little bit you can open the door, but if its up all the way you cant?
Old Oct 2, 2008 | 09:46 PM
rkfguard's Avatar
yep..exactly...is there an adjustment on the window regulator, or is the window not aligned correctly
Old Oct 3, 2008 | 10:37 AM
estraw's Avatar
only thing i can think of is it needs adjusted. idk ive never seen that happen before lol. sorry i cant be anymore help
jplessard
Apr 26, 2012 09:14 PM
boulder
Dec 14, 2011 09:42 AM
madtodaimax
Feb 25, 2007 05:42 PM
jimweee
Feb 20, 2006 11:07 PM
duwacker16
Jul 10, 2005 05:51 AM
