Eats allot of gas
Old Sep 1, 2005 | 09:46 PM
DSMTalonAWD51's Avatar
Default RE: Eats allot of gas
ORIGINAL: get435
it might be a bad idea to chang to synthetic if the car never ran it it can cause oil leakes and chaging what kida oil the car takes can help or hurt the motor depending on how it was treated in the past most machanics say if it has over 60,000 on it and never ran synthetic dont use it it may cause problems.
crock
ORIGINAL: Patrick
what kind of problems??
if you have an oil leak, synthetic is thinner, so it may leak more...it never 'causes" a leak..
truth
Old Sep 1, 2005 | 09:48 PM
ORIGINAL: TheAdvocate
What do you consider eating gas? 20 miles to a gallon? 15? 25?
yes be more specific. drive soft, calculate your mpg and report back. saying it eats gas could be what others consider normal for that car or maybe you just have a heavy foot.
Old Sep 1, 2005 | 10:08 PM
TheAdvocate's Avatar
Ya... I get anywheres from 20-24 depending how I drive with my GST...
Old Sep 4, 2005 | 10:15 AM
get435's Avatar
When the odometer on your vehicle hits the 75,000-mile mark, it's time to start using a different type of motor oil. If you want to keep your car, truck or SUV running smoothly for another 75,000 miles and more, switching to special motor oil now can help slow the aging process and extend the performance of your older vehicle. Here are several reasons why.
Normal Wear and Tear
As your engine reaches 75,000 miles and more it begins to age, which requires some additional protection. Some indicators of engine wear and tear are increased oil consumption between oil changes, an engine that is slow to start on a cold morning or runs hotter on warmer days, a decrease in throttle response and gas mileage, and minor leaks. By taking a proactive approach toward your engine's maintenance, you can help inhibit its aging process and extend the life and efficiency of your automobile.
As a vehicle ages, and its mechanical performance decreases, a greater toll is taken on its engine's oil viscosity. The demands of an older engine break down the oil more quickly, rendering it less able to lubricate. The end result is an engine that no longer functions at its peak performance. Also, as the engine wears, oil consumption, oil leakage, or lower-cylinder compression may occur. These problems can lead to spark plug failure, excessive deposits and a loss of power.
Further, seals become brittle, rings wear and valves may not seal as tightly. Deposits can build up on fuel injectors, valves or piston rings, so they don't operate as smoothly. Diminished ring sealing allows more than the usual amount of combustion gas to contaminate the oil. This results in more rapid oil oxidation, which causes the oil to thicken and age prematurely and may ultimately explain why your engine takes longer to turn over on cold mornings.
Time in a Bottle
Before you ponder any expensive or unnecessary repairs, consider that the solution may be as simple as switching to an oil made for engines with over 75,000 miles. These oils are designed to provide specialized protection for your vehicle's engine by containing anti-wear additives, seal conditioners, extra cleaning agents and friction modifiers. These elements are designed to work together to condition engine seals, prevent leaks, minimize oil consumption, provide easier cold starts, improve power output and resist thermal breakdown — all of which will help maximize the life and sustain the performance of an older engine. These oils don't evaporate as easily at normal operating temperatures so ultimately less oil is consumed. The additives in oils made for engines with over 75,000 miles increase its resistance toward thickening thereby providing easier and faster cold-starts. Cleaning agents help reduce deposit formation and prevent horsepower loss, plus special friction-reducing components help maximize fuel economy and power output.
What if your vehicle has less than 75,000 miles? Are there any advantages to using this oil in a car with fewer miles on it? Actually, you could start earlier with these oils to prevent aging effects and to help further preserve the life of your vehicle's engine. Once you switch to an oil formulated for engines over 75,000 miles, you should continue to use it in order to get the maximum benefits. Alternating between this oil and all-climate oils won't harm your engine, but you won't get the full benefits.
Benefits
According to R.L. Polk & Co., the longest-standing curator of automotive records in the United States, consumers are keeping their vehicles longer for the first time since the mid-1990s. The median car age recorded in 2002 was 8.4 years, "the highest median age since we began tracking the statistic in 1970," said Mike Gingell, vice president of Polk's aftermarket division.
That median age means that more cars could soon be facing many of the problems associated with higher-mileage engines — and may benefit from the use of a high-mileage oil. The specific advantages of using a high-mileage oil in your higher-mileage vehicle are:
Conditioned engine seals
> Helps prevent oil leaks and deposit formation
Cleaner engine/Reduced formation of deposits
> Helps prevent horsepower loss
Reduced oil consumption
> Helps provide faster and easier cold starts
Extra wear protection
> Helps increase fuel economy and extend engine life
sorry it was 75000 and one of the reasons it may be a bad idea to switch to a supersyn oil is "The demands of an older engine break down the oil more quickly, rendering it less able to lubricate. The end result is an engine that no longer functions at its peak performance. Also, as the engine wears, oil consumption, oil leakage, or lower-cylinder compression may occur. These problems can lead to spark plug failure, excessive deposits and a loss of power." its not that it may hurt the motor right away but it can lead to it or cause it because a pure synthetic racing or hipo oil is alot thinner and can accelerate the rate at which these can happen.
site
Old Sep 4, 2005 | 11:02 AM
slow420a's Avatar
When I first got my car it had 85k on it and the guy who had it was putting ursa crap in it. The first oil change I did I threw in some mobil one. Now the car is at 120, havent had an oil leak yet and I beat the **** out of my car every day. Bottom line every motor is different, If you have an lt1 with 200k I'd say get the high miliage oil b/c its had a tuff life, and its a domestic motor. Where if it were a honda civic I'd say put some cooking oil in it and call it a day.
P.S>I am not knocking domestics, I drive a chrystler.
Old Sep 4, 2005 | 01:13 PM
get435's Avatar
you havent had a visable oil leak right. it wont happen to all motors but most it will that is why it is a recomendation not required.
Old Sep 5, 2005 | 11:03 AM
do you believe everything you read? especially when the source is a company trying to sell you a product? its called marketing, and although the theory may be somewhat correct i call crock on that based on personal experience as i have to switched to synthetic on an 80k mile motor with no issues whatsoever. no one buys valvoline synthetic they buy either mobil one or castrol syntec, so im sure they would love to steal some of those customers with their special "high mileage" oil. sources should be non biased case studies not what an oil company puts on their website.
Old Sep 5, 2005 | 11:17 AM
get435's Avatar
not just the retailer that sold the product said it many upon many mcahnics have told me the same thing along with all the macines that have built my motors in the past which they know what could happen like i said it dose not happen to all motors but there is still a chance that it could not "cause the problem but aid it in getting worse "some things". i would take the word of somone that builds motors for a living and dont give a sh** what kinda oil you use but can tell you what he has seen and gives sugestions.
Old Sep 5, 2005 | 04:03 PM
I agree with both of you... There reasoning behind it is correct... But they are stretching the truth about it, and making it sound more important than what it is... If it made that big of a difference, they would of had it a long time ago.
